hoser
Jim, I can give you some pointers on the install for 98-02 model years...
I used Whiteline bushings and do recommend them. I did not remove the rack but swapped out the bushings on the vehicle. The large one is relatively easy, no explanation needed. I suggest removing it first, then work on the smaller bushings and lastly install the big bushing.
The driver's side bushings can be pressed out. Loosen the rearward bolt slightly. Then remove the forward bolt/nut completely. I just rotated the rack slightly, then jammed a screwdriver in there and used a floor jack to push the bushing out.
The new bushing pictured in previous posts consists of an upper hat, lower hat and a sleeve. You need a bolt/washer/nut that is about 1/2" longer than the stock bolt... probably about 5-1/2 to 6" in length. The one I used it too long and needed a socket and/or stack of washers. Threaded bar with one nut on each side would work better.
Same process for removing the rear bushing. But installing the new bushing trio can be the tricky part. I installed the lower bushing (hat) first. Then when lining up the sleeve and the upper bushing, there was about a centimeter of room between the bushing and oil pan.... and not quite enough for the nut. I fought it for a little bit but in the end, just decided to loosen the smaller DS engine motor mounts and lift the engine just slightly (wood block under oil pan). That extra bit of room was all that was needed. An alternative would be to grind down that nut pictured above by about 1/2 height. Obviously, YMMV.
HTH
HTH
