first time. Not “hard” In fact pretty easy after you get one out and successfully back in. But there can be two challenge spots; knuckle removal (ball joint disconnect) and axle re-install ( there is a technique to get the axle to easily snap in-place). Do it per FSM steps and completely remove the knuckle its much easier and gives better access to cV.The link was found via google shopping for G2 Axle G2 AXLE & GEAR | HOME....the last two days I’ve attempted to speak with them via phone just to see if it’s legit. No success yet in speaking to them. Sent them an email via there website just now so I will post up here if any good news comes of it.got a link? I've wondered why the aftermarket doesn't have many stronger options for these trucks.
Toyota shafts are just a lot of money. I talked to a LC specific shop and they suggested Napa stating better quality. I replaced mine with what my local shop recommended. They have a lifetime part and labor warranty and much cheaper than OEM. I think OEM is always best option but if you can’t afford that there are some good aftermarket options also.
EDIT, in December noticed leaking on both outer sides where boot meets axle........Toyota replaced at no cost, was days within 1 year warranty. Still had to pay the cost for replacement at my shop, fairly pissed since I paid the cost of oem for this NOT to happen. SPC uca's and slee diff drop. Did some moderate wheeling in sw Colorado last July but nothing major.did the same, bought new oem, no regrets.
Only problem is that the warranty for all AM axles states that they are not intended for Offroad use or use with lifted vehicles. Depending on how stringent your local NAPA is, that may or may not cause issues.I’ve put nothing but OEM axles and reboot kits on this truck since purchase five years/150k miles ago, and even still I have ripped several boots, and I fully BROKE an axle a week or so ago. Obliterated the cage on the wheel side. Strongly considering aftermarket since the warranties seem to be better and I keep having problems. I could buy two NAPAs for half the price of a single unit at the cheapest available OEM price, so I’d have a spare for the trail. I’m seriously debating going aftermarket this go around. Am I crazy?
I presume the dealer would be the same. I’ve never been able to get a warranty out of a part I’ve installed myself anyway. Usually one place needs to install the parts and do the labor, in order to be available for warranty replacement. Otherwise, you could’ve screwed it up when you installed it. At least that’s what I’ve been told.Only problem is that the warranty for all AM axles states that they are not intended for Offroad use or use with lifted vehicles. Depending on how stringent your local NAPA is, that may or may not cause issues.
I’ll have to grab my tape measure, but I’m running stock AHC. Only thing that isn’t stock is my 33” tires. Are you suggesting a diff drop?RE: Aftermarket CV assemblies; you'll get even better at swapping them out.
@Das Shtig what's your resting front suspension height measured from ground straight up to lower lip of fender? I'm not a bet'n man but if I was I'd guess its fairly high. That, IMHO, is the single reason some guys go through CVs prematurely...
Yeah it would help if nothing else. Seeing as you bust so many axles I would look at what you are doing to bust them and see if it is just something that you should be changing your process or accept as part of what you do.
Other option would be to save up for @TRAIL TAILOR new 100 series SAS conversion. Less likelihood of snapping axles at that point.
