Regearing; master install kit question
Olympia, WA
I'm planning on regearing to 4.88. Before I order, is there a few mandatory gaskets that need to be changed at the time or do I have to order the master install kit and everything? While I'm in there I probably should change everything but I'm curious what others have done.
Thanks
Thanks
Yes, many gaskets and seals to consider. Give this Re-Gear Frequently Asked Question guide a quick read:
We stock everything you'll need @ Cruiser Outfitters. Let us know if we can be of help!
I'm rebuilding a set of 93' locker axles and have the stuff for them. I decided to regear them while I'm in there so I'm figuring what I need.
Thanks for the FAQ Guide link, I will go through it.
Give us a shout if we can be of any assistance, we literally sell these regear and axle overhaul parts all day long :D
Does this look right for 1993 axles with OEM lockers?
1 - TOYLC488R - Front 4.88 Ring & Pinion Set
1 - IKTOYCFE - Front R&P Install Kit
1 - TOYLC488 - Rear 4.88 Ring & Pinion Set
1 - IKTOYLCBE - Rear R&P Install Kit
1 - DG60080 - Front Paper Differential Gasket
1 - DG60070 - Rear Paper Differential Gasket
and just 1 - PN35110 - Spline Pinion Flange Kit or do I need 2?
Yes, that covers the diffs themselves. You need a single PN35110, only the front requires a new 29spl flange.
Let us know!
