Rebuild or replace power steering pump? (6 Viewers)
Enumclaw Plateau
The truck came with this power steering pump. It still works but the bearings seem to be going out because it now turns pretty hard and gritty feeling. I know it’s made by Toyota but nothing more than that. Would it be cheaper to just buy a new pump or rebuild what I have?
TIA
I don't think rebuilding is a great option, having read about others who have tried.
good used, or valley hybrids saginaw setup, @orangefj45
some have tried auto parts stores rebuilds with not much luck either
I saw that City Racer sells a new pump for $295. I went to Valley Hybrids but I didn’t see anything listed in the way of a PS pump. I was really hoping a rebuild kit would be a good option. I see a number of pumps on Amazon for as little as $35 too but I assume they’re junk
over in the 60 section, should be the same for a 2F in a 40
I was hoping Georg would chime in
you can always call them
I'm wondering if your 2F has been swapped out as it looks like you have a stock setup but a 77 block would not be drilled and tapped for the stock bracket
I bought the one on rock auto, i believe. You reuse your old reservoir. Has been working fine for a while (almost 2 years).
Did not recall a CR option being available at the time.
City Racer site is paused currently for the upcoming holiday, but I believe that the PS pump listed there is sold out.
I rebuilt the ps pump on my BJ 60, which looks to be the same pump, using a rebuild kit from RockAuto. 4 years later, it is still going strong. I think it was a Gates kit, and the rebuild was surprisingly easy I thought. But I could imagine that if the pump has significant wear on the various internal parts, replacing just seals and bearings will be a band aid fix. Bottom line, you have to start with a decent pump for a rebuild to make sense. I think this is why buying a rebuilt pump is hit and miss.
I’ve also bought a new ps pump for my 42 from City Racer. It seems to be a good quality pump and has worked flawlessly for many years.
