Malleus
Far west of Siegen
BumpWhy not use brass?
Well, I should have run and knocked on wood the second I saw this thread.
I had new Magnaflow muffler and hangers installed yesterday. My exhaust guy brings it down off the hoist and while I am paying him I see a nice bright green puddle developing on the ground around where the cats are.
I take a closer look and it is coming over the heat shield. My rear lines are now toast. Bypassing for now, but I do like my rear heater in the winter. This will be a fun job.
Nice timing!
Don't quote me on this but, I think it is possible the two pipes are supplied as one unit? mine fell apart so would not know but, if they are then the welds used to keep them together is the fail point, or more correctly starts off the corrosion process, the paint not adhering too good at this point.
The fuel filler pipe and vent pipe are welded together and this where mine started leaking diesel as it rusted through, coincidence?
Regards
Dave
My understanding is you have to drop the trans to get to them.I guessed the pipes may have some welding involved, I am thinking drop exhaust, (bolts are new), drop the heat shields and give it ago at replacing them properly?
Regards
Dave
Entirely possible, it is not necessary fon the manual versions, perhaps the auto bell housing is bigger?
Regards
Dave
Apparently there may be a way to get them out. It is tricky but I remember someone posting about it a while back.
Bump
So it sounds like if something happens to the hard lines its significantly easier to replace them with hoses (assuming you want to keep rear heat). Good to know just in case.
That's a great reference! I love chemistry, especially now that I don't get a grade for considering it. However, I think this is what you're referring to (not the definitive source, it's just the first item on the search list): Galvanic Corrosion | Penn EngineeringI believe this quote/bump/reply is because of what I posted earlier, ..tbh, im not sure what I was thinking exactly at the time, but I obviously had a train of thought going something like this:
Here's a link:
Cooling Systems Corrosion - Application Note - Lytron Inc
I am fearful of using certain metals like brass and especially stainless in the cooling system, because if the coolant were to deteriorate and/or a grounding issue occur, then galvanic corrosion could impact the aluminum head. And the aluminum would loose.
My understanding is that is why "copper & brass" radiators were phased out when aluminum heads came around for this very reason.
A small amount of brass, like on the engine drain plug, isn't a big deal (likely a specific type of brass) , but the more mass of dissimilar metals added to the cooling system, the bigger the impact. It is especially true with stainless steel.
There is also more "bad" chemistry that can happen when the propylene glycol breaks down after sevetal weeks into undesirable acids when coming into contact with certain metals as well.
Generally speaking, the phosphates and other corrosion inhibitors will minimize the risk, but if too much water gets added, a grounding problem happens, or the antifreeze breaks down, the dissimilar metals could cause a problem. All it takes is a few ions in the wrong direction and your engine block becomes a sacrificial annode.
This is my operating philosophy, please correct me if I'm wrong.
