After returning from SnT I have some SERIOUS rear sag going on. You can see from the pictures that the rear shackle angle is pretty far back and when loaded down and on the dunes the shackle was hitting the perch (blue arrow). Just after the tire carrier was installed I noticed the shackle angle change. Are these springs just flattening out? Seems weird to be hitting the perch rather than bump stops (I suppose this is due to the elongation of the spring?)
These are 10+ year old 4" Skyjacker Softrides that have been great for me and I really liked the way they sat for MANY MANY years. I am considering just replacing them with the same, but am worried that all the weight (tire/cooler carrier, aux tank, hi-lift) in the back is going to cause a sag if I match the front and rears. I've read the FAQ's and I understand everyone has differing opnions but, I DON"T WANT TO go SOA, and don't want bigger tires than 33's. Add-A-Leafs seem like a waste of time for the long run and I am interested in the OME's but they don't have 4" springs. Should I consider adding longer shackles to OME's and call it good. Anyone running the equivelent of 4" OME's (2 1/2" OME's w/ shackles?) I do mild wheeling, mex trips, and an occasional 200+ mile round trip to work. No need for extreme suspension but I do want to be able to wheel effectively.
I have very limited knowledge on suspension so any help is appreciated...
Oh yeah, and I'm not opening the door for another Spring-Over debate.
