my 1978 is my daily driver so i did the rear disc. it stops on a dime now... every time. safety 1st. if your rig is a garage princes that only goes out on sundays to starbucks and back then leave it stock. other wise the rear disc is no brainer.
When I did mine I decided to go with 4 piston Wilwood's on all corners. To assist with brake bias I also choose calipers for the rear with different size pistons to minimize any in-balance.
Byron,
What did you use to mount Wilwood calipers onto Toyota axle flanges at the rear and did you also use Wilwood rotors?
I've used Wiwood brakes on two cars and am a pretty big fan of their kits. When I went looking to see what they do for land cruisers there wasn't much. I knew I could make a bracket but didn't see ways to use other than Wilwood rotors and be sure ahead of time that their calipers would fit and work well since disc brakes are pretty much all about the thickness of rotors. So, with the most expensive loaded Monte Carlo calipers in RockAuto running less than $38. per it seemed like too many questions remained before putting down the approx $250. for Wilwoods.
I've got to also admit that the prospect of lightly built Wilwood aluminum calipers on my truck didn't fit well with my idea of what the FJ40 is. I mean Wilwoods are great for a restored car or a sports car, even one that's taken out for track time but having them on the rear of my cruiser seemed like it could end up being a too rough and tumble environment for them to withstand for very long.
I do have the machine tool ability to mill the S-10 rotor centers to the needed diameters.
I thought the S10 rotors were 5 lug. Maybe S10 calipers?
Rotors usually come from mid 90's GM full-size 4x4 truck for this conversion.
If you do go with the GM Metric Calipers be aware of the balance issues. If you read the conversion posts I believe the majority of conversions state a difficulty or inability to get proper brake bias regardless of using a proportioning valve. One option is Wilwood 2" calipers. They are not small enough, but better than the stock GM 2.5" ones. The downside is cost at about $80 each without pads or parts.
Yeah, that's the bugaboo, and it doesn't help to see several people describing that they've got their adjustable proportioning valve set to its max limitation in order to get what they feel is an adequately safe and balanced system.
I've got the GM calipers and am waiting on racer65's proportioning valve. All new clutch and brake hydraulics gives me time to keep mulling this balance issue over. I'm now starting to wonder about a Toyota caliper for the front brakes (the truck is a '77 and has stock front discs) that's larger as another way to make a front/rear balanced system.
