Rear diff strange moan noise
Luxembourg
Hello,
Since a few months i have a strange noise coming from the rear diff. The noise is there in low speed, no mater if i accelerate or not. It sounds like a bearing moan. I thought it was the rear wheel bearings. I replaced them and the noise is still there. Lo leaks, no play on the drive shaft. Could it be the pinion bearing?
I might check my u-joints before i dug into the diff...
Hi, I removed the rear driveshaft and drove in 4H. No moaning noise! So it could be the U-Joints moaning? I thought U-joints tipical noise was clunk or click . I think i order 2 U Joints and give it a try before i open the axle, what do you think?
New joints, still noise but now i found the culprit. The outer pinion bearing.
I got the race out too
I looked through the hole at the inside and the inner bearing looks good.
I'll replace that outer bearing and the oil seal and should be good.
No grease.
