No metal cutting required on the late model 80 series with the foam headliner. That's the picture of my 97 LX450 with dome light mounted in the cargo bay.
*Remember* the light will not work correctly with the doors until you have it grounded to the body. Just a little heads up tip.![]()
Awesome! I have a 93 and will be anticipating how this turns out. Keep us posted.I started mine tonight and I started bumming as soon as I looked at the postings. I did not see any done on a 93. I went out and looked and really started bumming, I did not want it to look bad when I was finished so I came in and read until my eyes bled (or at least it felt like it).
The first problem is running the wires in the head liner because of the headliner is the cloth material and not one piece.
Then a I ran across a wiring diagram in a post where someone had trouble with the wiring I believe and it showed a rear dome light harness. I did some digging and found out the 93's have the wiring harness in there... somewhere. So I took things apart and looked and I could not see it. Then I stuck my fingers in a hole and felt a connector not connected to anything and tried to dig it out. It was tough because they had it all taped to the harness but with some work you are able to bring it to the opening and cut the tape and unravel the harness. I reaches right over to the center where you want to mount it.
My excitement stopped short when I looked up and did not see an opening for the light. So I took my light, made some measurements, drew it up and printed out a template to use for my dremel. I will finish up tomorrow but I wanted to post some pics for those who have a 93 or 94 and want to do this mod.
It works with the doors but the "On" position which by passes the doors does not work. Weird.
