So I'm upgrading to RCV's up front, what are the best options for the rear axle? I primarily wheel in the snow where weight does matter a little, but it would also be a really bad place to get stuck if an axle fails. I'm definitely on a budget due to having too many projects, but I know that a rear axle failure in 4ft of snow 20+ miles from the closest point I could get a trailer scares me a bit...
I have read a few threads and it sounds like the OEM SF shafts are pretty strong but there may be a service life, and there have been problems with chromo shafts? What about FF conversions, hybrid axles, cut down 14 bolts? I would like to stay 6 lug just because tires are newish and I spent the time to build the 15" bead locks, but I'm definitely open to all options.
Current gearing is 4.56 but it's not low enough for the 39.5's and I'll be looking at options for lower gearing, whether it's diff, t-case, or something else sometime in the future as well.
Considering all this, what are the best options for the rear axle?
