Where did you source new bearings?
Local dealer gave me a part number of 90365-47005 that was replaced by 90365-47007 but discontinued.
We stock em
Here is mine. Yours was just way easier to get loaded! I have been following your progress. I am right behind you in the process. This is my first go at a restoration of any kind. Your pictures and details have been a huge help.View attachment 1369699
These bearings rarely go bad unless the rear axle runs low on gear oil.
However, they do tend to get beat up pulling them out, so if you can leave them in place, the seal is easy to replace. But if you go to the trouble to pull them out, I would only put new ones back in. Take a good look at the rollers-any hint of pitting or rust, I would just replace. In fact, I'd recommend you replace them if it's all apart anyway. That's just good practice.
What is the trick to remove the race on the pre '73 axles?
The fast way to get them is to remove the rollers and then weld a bead all the way around the race. When it cools the race shrinks and it will just fall out.
