Rear AC not blowing cold (1 Viewer)
Texas
My rear AC is not blowing cold but my front works incredibly. Wanting to tackle this before it really heats up in Texas. Any suggestions before I go down a rabbit hole?
I bought my ‘99 LC 3 months ago and then previous owner did confirm that he recently charged the AC with R-134A at 1.5lbs.
Thanks y’all!
Not sure 99 had rear AC. Do you have vents on the roof right above the 3rd row? the heating for 2 and 3rd row are located below the front seats and center console.
Thanks y’all!
If you do have a real dual system it will hold more than 1.5 lbs, check under the vehicle and see if you have lines going to the rear. Check your label under hood for amount of refrigerant it holds.
I looked up the specs. and for a dual system it holds 2.43 lbs and single unit is 1.75 lbs.
I have the rear vents and AC control on the roof yes!
I think this could be the problem. I do have a dual system.
I’ll get some more and charge it here shortly and make an update.
Thank you!
Thank you!
I would highly advised you take it to a shop and get it Evac and recharge to the proper amount, if you are over or under it could make a difference on the output and also you need to add some oil to the system to keep that compressor lubricated. Just my 2 pennies.
You have a leak in the system. Leaks in the lines to the rear are most common (runs down passenger side to right rear quarter panel). Follow the lines and maybe you'll find the leak (oily).
if the front works well and the rear doesn't work at all
my WAG is the rear is bypassed and capped off
especially if you just bought it
I have the same issues with front working fine but rear not as cold, is the rear refrigerant refill location same as the front? Where is it located? Is that something most mech. can do?
Remember that there is no way to measure how much is in your system without evacuating everything first. Just dumping in more refrigerant may help … or make things worse.
