Rear A/C and Rear heat delete (1 Viewer)
Frisco, CO
Yanking the rear heat and cool systems out of the LX. Got the front LC delete hoses on the way now and pulled the coolbox today.
The single a/c system lines I need are NLA so will need to pull from a part out.
I assume Toyota stamped one chassis for both the LC and LX and utilized body plugs for those that didn't receive these as options.
Anyone here that might be able to confirm this? I looked high and low thru the parts diagrams on the LC chassis but found no evidence of the use
of body plugs to fill these openings.
I can very easily cut some steel or Al sheet and seam seal in place, but it would be nice if the plugs are an option.
like the fan under the seat?? I had the hole welded over
