real time seafoam/PCV question
Discussion in '80-Series Tech' started by concretejungle, Oct 23, 2005.
  1. concretejungle
    concretejungle
    9,592
    804
    Oct 27, 2003
    North Cadillac
    I'm getting ready to change my oil and have a can of seafoam on the workbench. My question is which side of the PCV do i actually suck the seafoam from? Do i detach the hose from the top of the valve cover and put it in the seafoam bottle, or do i detach the hose from the throttle body and suck the seafoam in from there?
    thanks
  2. beno
    beno Gihee Arakawa Moderator Supporting Vendor GOLD Star
    25,277
    Media:
    382
    Albums:
    29
    23,235
    Aug 28, 2004
    Woodstock, NY, USA
    Yo CJ:
    Don't do it from the throttle body side because you want it to enter the throttle body to clean up the carbon deposits.
    You can either take off the hose from the metal valve and put the hose end into a jar with Seafoam in it, or if you want, you can take out the metal valve and hose attached to the valve and clean the metal part as well as the hose.
    Either way, you want to be careful to suck up the Seafoam slowly then turn the engine off. Then wait a few minutes and start up the rig...then GET OUT OF THE WAY!!!!!! LOTS OF SMOKE!!!!!
    Your neighbors might think your rig is on fire....it filled up my whole street!!
    Best.
    -onur
  3. firetruck41
    firetruck41
    5,732
    34
    Mar 27, 2003
    Camas, WA USA
    I was advised to pour the seafoam (slowly) into the hose instead of using a hose to suction it, something about sucking it all into one cylinder at one time and a cylinder of non compressible fluid causing damage, don't know if that is really possible, but I didn't want to take any chances. There will be A LOT of smoke, tell your neighbors not to call the fire dept ;)
  4. e9999
    e9999 You want to do what...? Moderator
    16,737
    593
    Sep 21, 2003
    US
    you can just suck the seafoam slowly in by just barely touching the surface of the liquid, it'll suck some air too but if not too much it'll keep on running IIRC and then the SF is atomized too better. Further more IIRC I did suck it through the PCV valve which is then cleaned as well....
    Mine didn't smoke much at all, maybe cuz I had cleaned the TB before.
    Didn't seem to make any difference in how my engine runs.
  5. concretejungle
    concretejungle
    9,592
    804
    Oct 27, 2003
    North Cadillac
    OK, thanks for the info. So, i will be litterally sucking the fluid into the valve cover?
    I will remove the hose from the area pointed in the pic and allow it to slowly suck/pour into hose. The fluid will enter into the valvcover and move down. hope this is right.
    Thanks,
    EDIT: i guess i could just pull the hose and see which way it's sucking :doh:
  6. Cruiserhead05
    Cruiserhead05
    3,611
    198
    Jun 25, 2003
    Rixeyville, VA
    I think its the other way around. you detach the hose from the valve cover and suck the fluid in the throttle body
  7. concretejungle
    concretejungle
    9,592
    804
    Oct 27, 2003
    North Cadillac
    Well, scratch this idea until another day. THe hose and PCV grommet is brital and in pretty bad shape. If i go tugging on it, there is a good chance of damaging the hose and/or grommet. So i'll order the parts from cdan and do it another day.
  8. beno
    25,277
    Media:
    382
    Albums:
    29
    23,235
    Aug 28, 2004
    Woodstock, NY, USA
    CJ--
    The hose you mentioned in the picture is not the end to do it from. Do it from the OTHER end of the PCV hose...you can do this without taking the valve out too...you can suck through just the hose...It still works that way.
    -onur
  9. e9999
    16,737
    593
    Sep 21, 2003
    US
    it's the other way around dude! the point of the PCV is to suck oil vapors into the engine so they don't pollute... so it's gotta suck out of the valve cover into the TB, right...? :)
  10. concretejungle
    concretejungle
    9,592
    804
    Oct 27, 2003
    North Cadillac
    THanks fellas. Gotcha.
    Beno, i'm affraid to even tug on that hose at all. I gave it a few good tugs and it feels as if it's stuck onto the pcv grommet fitting really tight. I took some hose pliers and it just started to crack. So i stopped. I'll get er' done next time.
  11. Arya Ebrahimi
    Arya Ebrahimi
    3,422
    111
    Dec 2, 2003
    Rockville, MD
    You could use the vacuum hose for the brake booster. I cleaned my throttle body this past winter(had it off already), but never got around to seafoaming the motor. Just follow the hose that goes from the brake booster to the intake manifold and disconnect it back at the brake booster. It's long enough to use as the suction hose as well. It may not be the most centralized port in the manifold, but I still got a TON of smoke afterwards and the cruiser runs a little bit better(still pings though under hard acceleration which is what I was trying to get rid of).
    Ary
  12. e9999
    16,737
    593
    Sep 21, 2003
    US
    plenty to read here on the dreaded grommet incidents and how to avoid them...
  13. concretejungle
    concretejungle
    9,592
    804
    Oct 27, 2003
    North Cadillac
    so how long is she gonna smoke? :D
  14. Pskhaat
    Pskhaat
    2,631
    4
    Aug 19, 2003
    Morrison Formation
    20 mins maybe? most.
  15. DRTDuck
    DRTDuck
    624
    11
    Mar 28, 2003
    Boulder, CO
    Mine did not smoke much and only for a minute or two. I had previously cleaned the throttle body. I let it sit 5-10 minutes as everyone else has descriped.
    I spoke with someone who let it sit for a couple of hours (was not on an 80 or even a toyota IIRC).
    Any issues with letting it sit for a long period of time such as a couple of hours?
  16. concretejungle
    concretejungle
    9,592
    804
    Oct 27, 2003
    North Cadillac
    I let it sit for 3 minutes then started it. It smoked (picture above). Shut it off after a couple minutes of idle and smoke. Let sit for over an hour then started it. Been smoking for about 5 minutes. I'll let her run a little longer.
