TEXASLAWMAN
Drivers side brake caliper top bolt came out and is missing. What size bolt and thread is it???
Haven't tried it myself, but someone said a while back that one of the big bolts that hold the front tow hooks on, or bumper bolts will fit. Please post if it works!
Might have to order up a set for both sides when I do my brakes. Keep the old ones as spares!
What about the rear caliper bolts?
Crazy, my bottom one just came out yesterday, glad to know it's relatively common and that I'm not alone in this! I just ordered from Amazon before I saw this thread. There are plenty of links, but just for posterity it is a M12-1.25 thread at 40mm long!
If it won't torque to 90 F.P. it may not be bad threads, but in fact is the wrong grade* bolt. A lesser grade bolt will not be strong enough to reach 90 foot pounds of torque, but will stretch under that much torque. *Note, calipers bolts are in fact a SAFETY item, and should NEVER be replaced with ANYTHING other then the exact same grade bolt. The factory caliper bolts have the number 11 imprinted on top of their head, denoting their high strength.90ftlbs on front for torque, if it won't torque you need new threads inside
Yes he just bought new correct bolts and lost one so yes the threads could be boogeredIf it won't torque to 90 F.P. it may not be bad threads, but in fact is the wrong grade* bolt. A lesser grade bolt will not be strong enough to reach 90 foot pounds of torque, but will stretch under that much torque. *Note, calipers bolts are in fact a SAFETY item, and should NEVER be replaced with ANYTHING other then the exact same grade bolt. The factory caliper bolts have the number 11 imprinted on top of their head, denoting their high strength.
