Rare clunk in my shaft when I put D or R (3 Viewers)
Colombia
Hey.
I have a rare noise when I put my 100 in D or R, I changed the CVs (those CVs were too old and damaged), the noise deceased but still there.
Could it be the universal joint in the drive shaft? This noise is awful.
Hey.
I have a rare noise when I put my 100 in D or R, I changed the CVs but the noise is still there.
Hey.
Could be a few things. Excessive lash in one or more diffs, transfer case, or u joints. (Spider joints) also the front diff support is known to cause this clunk. See photo from cruiserpatch.
Potentially diff mount bushings. Replacing mine has made a world of difference.
U right, I´ll check them.
Thanks man.
Could be a few things. Excessive lash in one or more diffs, transfer case, or u joints. (Spider joints) also the front diff support is known to cause this clunk. See photo from cruiserpatch. View attachment 3981396
The transfer case is in great conditions, however I need to check the front diff support.
Thanks.
did you change the drive flanges with the front axle change?
you can remove the front driveshaft and engage the transfer case lock and drive on rear only and see if the noise goes away, then you know which end of the rig to focus on
Mb u are right men. I dont changed the drive flanges.
My conclusions until now are 3:
1.Replace the diff mount bush.
2.Spider joints.
3. Drive flanges
