Yes, you are correct on the 16x8 +0 which would be 1.5" outward from a centered 8" wheel.
I was running a FJC wheel with 1.25" wheel spacers at approx. 3.75" backspace on a 7.5" wheel (same as a 9" wheel 4.5 BS & a 8" wheel 4" BS) that centered the tread right on top of the wheel bearings. My new wheels are outward 1" from where I was. This has now required me to lower my bump stops.
Does this help?
Sorry this is off topic of Dobinson Tapered & 37s
It’s inportant to not just look at offset. My 17x8.5” -6mm rims are stock backspace, but that means the extra .5” of rim width is all to the outside.
If you went 17x9 in those same specs, you’d be 1” wider to the outside. A 10” rim would be 2” wider.
I would personally stay 17x8.5 since pretty much every 12.5” wide tire specs to 8.5” minimum rim width (understanding that those specs are probably relevant mostly to tire warranty), but wider tires are harder to deal with than larger diameter.
The number one issue most people will face is picking a wider rim when going to 17”, and then having problems with the tire tucking inside the fender lip, and that tuck is critical if you don’t want to lose suspension travel or trim for clearance.
37’s fit diameter wise plenty easily - it’s width and how your suspension travels that determines how cleanly it happens.
I ran 37” trxus on stock rims with 1” spacers no problem and that tire is as big as the STT Pro. But it curves inward and the tread width is only 9” and change so the tuck is completely different than a squared off tread design. It was overall a cleaner fit than the ko2 on 8.5” rims, despite being a full inch larger.
Sticking with 35’s isn’t the issue, it’s that you have to be careful with more variables on 37’s.
Compare this tuck to even the ko2 - it’s much cleaner because the ballon style of the tread angles it inward. As compared to the squared off STT Pro, it’s obvious my backspacing is now not ideal where it was before on the same size max size 37” tire.
That’s the 3.5” F.O.R. Gen II suspension BTW. Here’s the video. The first half being poor spotting and worse driving.
This is also still on F.O.R. Gen II. Some points of good stuff of the ko2 here.
