At an 8000 lbs winch load the Warn 8274 has a line speed of 6.10 fpm and a current draw of 450amps. The Ramsey RE8000 under the same load has a line speed of 4.3 fpm at a current draw of 370amps. At 80 more amps of draw it damn well better be faster and you probably need to run dual batteries if your going to be serious about using it. I will grant you that the 8274 no load speed of 73.4 fpm is considerably faster than the RE8000 20 fpm. The worm drive will outlast the spur gear drive of the 8274 due to the fact that given the same load; a worm gear has less pressure on the teeth than a spur gear does. Personally, when I'm aiding someone in a recover, including myself, I’m far more concerned about a safe recovery with the least amount of damage versus how fast I do it. You may not like them, but the military certainly does and they do not buy second best. The next time you see a flat bed car carrier it will most likely have one of two winch types. It will be either hydraulic or worm gear. If you come across one running an 8274 - let me know.
