Radio Tech (1 Viewer)
So I re-capped this radio (08600-00014) and powered it up while monitoring the temp around the audio output transistors, and it got very hot. Tore it back down and tested those diodes and they were out of spec a good bit. Also tested the other PCB mounted diodes and they were right on. Replacements for testing are in the mail.
This also arrived. I've been hunting this for a long time. Service manual for an AM/FM radio using the same Panasonic circuit used in the 60 series trucks (90A05 and 89118). Microfiche is hard to read, but it works.
Received these in the mail today, couldn't wait to check them out. These are the replacement diodes for the 08600-00014.
Put a couple on the tester...much better
Test running on the bench now, running cool. @ToyotaMatt, your parts came today too so you are on the bench tomorrow.
I had this unit on the shelf so I decided to go through it. 86120-60020
It was DOA, looking further it has an open trace on the power input board, this is weird.
Installed jumper.
Replaced capacitors - ready to go.
Russ ,
it appears you are not alone ?
and you have new Teq OEM Audio competition going on too .............
That video is odd. What else can I say?
Thanks to @Engineer8000 and his repair work, I have an as-new working ~1974 AM radio in my '78 FJ40. The POs bent back the OEM radio brackets, so with some hammering and prying, the radio is installed as it would have been at the factory on those tabs, with bolts. I get 5 strong stations - one for each preset.
posted with permission of thread starter ...
finally a real nice period correct face plates solution exists , injection molded exactly how TOYOTA made them 5 decades ago ....
- only TOP SHELF , only TOP SHELF all the time ....
Thanks for your Support of @Engineer8000 , Russ is the BEST at what he offers our community , nothing i have seen , or nobody i have met in my TOYOTA lifetime even
scratches the surface of OLD SKOOL Traditional Gear , combined with all the same exact things i also hold dear ...... :) 🎇
Thanks Russ !
The community needs the knobs (I know there are some 3D printed options out there, but they're not close enough in my opinion) as well as the above face plate with the option, "TUNER". TUNE was for the later National radio 79-8X and frequency began at 53. The earlier National radios (75-78) had a "TUNER" naming convention and freq. started at 54. The Fujitsu TEN radios had a faceplate like the one @SteveH shows above in his photo, correct for that radio.
intriguing Dallas , as always ...
i DO not see @SteveH 's faceplate often ?
UNICORNS can be Kloned , if you have a solid nive grade A willing donor ....
are you saying that @SteveH ' s plate has a TUNER variant , or my injection molded one does , or both ?
some SOLID clear TECH images , would be good eye candy to study up on here , providing @Engineer8000 , is OK , ? with the discussion here , or maybe a stand alone TECH tread on 40 face plates or in the RADIOS SUB FORUM too ?
thanks Dallas buddy .... :)
Generally speaking, starting in 1973 radios were either A) Factory/Port equipped National (PIO (port installed options) sticker in the glove box indicated) or B) Fujitsu Ten dealership installed. @SteveH above has the correct "Dealer-Installed" Fujitsu Ten 08600-00014 for a mid 70's FJ40. The knobs and faceplate on his specimen are correct for that radio.
The faceplate you have re-created, @ToyotaMatt covers: 86120-60020 (79-81), 86120-60021 (82). Big window, flat buttons. They changed the radio nearly completely for 1983.
This is all documented by Bill, quite extensively and with detail, HERE.
