Radiator for a 350 swapped 80?
  • Thread starter Sean Foster
  • Start date
  • Watchers 3
Sean Foster
Sean Foster
Colorado Springs
So I’m dropping a Chevy small block into my 80 and was curious what radiator I should go with. Any suggestions are welcome.
tmxmotorsports
tmxmotorsports
OBX Nc
Not a cheap opinion but a Ron Davis radiator all aluminum tig welded no plastic tanks.
lazy
lazy
Golden, CO
Steel nutz makes a great rad. Cheaper than rd, every bit of the same quality. Dimes stacked perfectly throughout.
tmxmotorsports
tmxmotorsports
OBX Nc
Yup. Mine should be arriving today in the mail.
You mean this
20211029 172244
20211029 172256
White Stripe
White Stripe
If your going up mountain passes and or towing you will need more cooling than a v8 swap that just goes down the highway and trail. So factor in your vehicle use.
lazy
lazy
Golden, CO
Not sure if Ron Davis does a swapped version, but a 5 minute phone call to Mike to get your rad ordered is well worth it. He knows were to put the inlet and outlets too. I paid $1350 shipped in 2016.
23
24
25
tmxmotorsports
tmxmotorsports
OBX Nc
6806goats
6806goats
Kuwait until I can't take any more.
Great topic which has me wondering what to do. I've been holding off to do an LS swap but I also have a nice running 350 (or used too when my bro built it years ago) and 700R4 that would make sense using. Or I could put that into my 68 C3500. Anyway, question is, will a custom radiator built for a SBC also work for an LS swap? Technically they are both small blocks I guess but might have different hook ups.
tmxmotorsports
tmxmotorsports
OBX Nc
In a sense yes I order them to match the ls inlet and outlet size so no mix matched hoses and also for a steam vent for the ls
Sean Foster
Sean Foster
Colorado Springs
So I never got the notifications for this thread but wanted to ask you about your suggestion, I can find 3 core full aluminum stock radiators for within my budget and I will be going over mountain passes but very little towing. I also do some decently serious wheeling so would you say look into a custom built radiator and bite the bullet or would the full aluminum factory one work?
NCFJ
NCFJ
Supporting Vendor
Chesnee, SC
I've been using Ron Davis Radiators for years without issue. Great product, fully welded all aluminum. As Tommy mentioned, set up for the LS with hose size and placement how you want it along with a steam port. I have had them with and without fans, with and without trans cooler. All top quality product. Electric fans stop running at about 34-40 MPH, the radiator is getting enough air to do its job at that point.
White Stripe
White Stripe
I would say a 3 core aluminum would probably work for your plans. Towing up a pass could strain it but depends on the load and the mountain pass. Just keep an eye on the temps in those situations. My opinion anyway.
Sean Foster
Sean Foster
Colorado Springs
Awesome, yeah the passes in Colorado can be hell but I don’t tow anything bigger than a super small motorcycle trailer and that’s kinda rare.
White Stripe
White Stripe
I have my old 3 core aluminum radiator I could sell you from my 5.3 before I upgraded to the 6.0. I'm in Colorado. PM me if interested
Similar threads
