Rad fan failure, replace or electric?
So my fan self destructed. Should I replace or go electric?
I hammered on the mount when I did the T-belt. Lost my cool a bit. I think I put the assembly out of balance and shook itself to pieces.
NO for electric.
if you haven't changed the fan bracket, probably a good idea to do it also.
and while your there the fan clutch.
lucky the piece didn't go into the rad.
No to electric. Stick with the stock set up.
stock is my recommendation. can't beat toyota design and reliability
Just make the stock system work as designed. It is more than sufficient.
Way cheaper and easier to go with an OEM replacement.
