@Willard do you happen to have your shopping list handy with part numbers? I picked up the refrigerant a while back on a roadtrip so I could avoid shipping all together. I know I need a new compressor and clutch. I'll probably end up getting a new drier and evap core at the minimum.
Does anyone know if I can vacuum test the system with a bad compressor clutch? I'd like to know my lines are good before I buy $500 of parts.
Got mine from Rock Auto and Toyota Directly. The expansion valve from Toyota is better than what Rock Auto had.@Willard do you happen to have your shopping list handy with part numbers? I picked up the refrigerant a while back on a roadtrip so I could avoid shipping all together. I know I need a new compressor and clutch. I'll probably end up getting a new drier and evap core at the minimum.
We’re you allowed to accept it or did you get smack?I bought R-12 freon some time ago (still in R134A timeframe) anyway the freon showed up at my door by ups. Had to be shipped UPS ground and as I recall there was some rule about the recipient having a A/C certification or license. What rules might be in play at present time I'm not sure....FYI
I work for a different parts supplier, although we carry Denso products and many others.
The company above is based out of Phoenix and took over the business when the former owner was killed. I don't know if they're still honoring the prices shown, they basically are using the format I set up several years back.
You can vacuum test the system if the clutch is bad (assuming the front seal is ok) but remember that vacuum pulls things together, pressure pushes them apart, but if it holds for an hour or so. you should be good.
Should anyone want/need advise on A/C problems or parts, I am the buyer for Merle's Automotive Supply in Tucson. My direct number is 520-620-9519 or email: rscofield@merlesauto.com
Rules are per EPAthe rule about the license was from the vendor (the place I bought it from), not UPS. Far as I know UPS was only concerned about it be ground only. Again this was a few years ago.
These are tight. I undid several of these bolts last week. I gave a few smacks on the bolt head with punch and they loosened without issue.View attachment 2060861 What in fresh hell are these hex bolts on top of this compressor made of? Soft enough to get stripped by a hex wrench but impossible to drill out.
been a while but most systems only take ounces and not lbs he should be okI really doubt that 3 lbs of R12 is going to do you much good. Where will you get more to fully charge the system if it is indeed empty?
I have pounds left over from my granddad's mechanic days. All good!been a while but most systems only take ounces and not lbs he should be ok
was replying to another post but messed up somewhere your good to goI have pounds left over from my granddad's mechanic days. All good!
