pbgbottle
Forum Lifer
- Joined
- Feb 8, 2004
- Threads
- 288
- Messages
- 5,553
- Location
- Cloverdale B.C. Canada
- Website
- www.instagram.com
hey guys just curious, i was greasing my drive shaft when i noticed the ujoint bearing caps or whatever they are called . where able to spin in there bore
only two of the 4 ,two opposite from each other (see 1st pic) u-joint is tight .what does this mean ?? any ideas ??
it is loose in the bore and can be spun with my finger still feels like it has the rollers and grease in it .joint is still tight.
and also while i was out looking at my parts rig 1973 40 i noticed on the front output of an early t-case and the front diff pinion both had round flanges mated to the small bolt pattern drive shafts whats up here ? didn't round only come on fine spline pinions larger driveshafts ?
see pic round flanges on a 1973 fj40 front end
rear diff had square pinion flange ?
2nd pic diff end, 3rd pic t-case end
pics show both ends off the front driveshaft
