Questions on spark plugs and timing w EFI (1 Viewer)
Crush 4
GOLD Star
Motor city
Questions for the experts. I was fiddling w the 75-40 today and wondered if the timing should be set any different when running a Howell EFI? Also, if anyone out there has a lot of experience w tuning the Howell system I would love to talk w you as I have a few questions on “ tuning” it.
Also the PO put platinum plugs in. Are these best for overall performance or should I run something else?
Thx
KY
EFI is nothing more than a better way to delivery air/fuel to the engine, no need to change timing.
The tune in the efi dictates where timing is set. Howell should tell you that number. Does yours have electronic timing control?
Crush 4
GOLD Star
Motor city
I’m a bit of a newb to this as it was put on by PO. I’m trying to sort through what I have
Which I believe is this... I’ll dig into manuals as well
Southern Colorado
I would install the original style plugs in any 2F rather than any plantinum. My AFI TBI (which uses GM components) had me set the timing at TDC, and it runs best there. I tried advancing it (using their suggested method) and it did not run as well. Your elevation (above sea level) could play a role in this, too. Best to get all the docs and read up on your particular system. There are some Howell threads if you search - or call the company.
