question re: Adding Carb cooler to my 77 (1 Viewer)
COLO~RAD~OH!
Hey all, I’m adding a carb cooler to my 77. It wasn’t born with one so I am trying to replicate the stock setup as much as I can. I’m trying to figure out where this little computer mounts up? I assume in the cab, and have searched a bunch with no real answers… thanks in advance.
COLO~RAD~OH!
i got the relays, fan & all wiring together from a member. so I tacked the fan mounting bracket onto the vent at the cowl. will be relocating my wiper bottle, adding the relay and fuse to the cab firewall below the heat duct ( more or less as shown above ) and then running wires through the firewall by the heater hoses. so the wiring not really close to stock locations but the rest is generally there…. next part of the project will be to update the coolant/wiper bottles to the style from the later trucks.
COLO~RAD~OH!
step two: move crap out of the way like washer bottle, apron, fender & wheel to make enough room to weld bracket onto my cowl & not stress the burn through marks as my cruiser is a patina rainbow colored jalopy.
COLO~RAD~OH!
Step Four: with mudders input, locate suitable spot for relays near heat vent on passenger side. Run most of the wires through that spot in firewall.
COLO~RAD~OH!
Step five will be to route the wires accordingly, grounds, hots and key-on hots.
And last step for me will be to relocate washer bottle to passenger side. so i have the later style overflow washer combo to go in.
then run power to pump and extend washer tubes and….. voila! I hope it all works —- hahah
Austin TX
You'll like the carb fan once you get it done. It made a huge difference on the warm starts in my '79. I didn't want to pay for an expensive FJ40 carb fan, so I used one from an FJ60 ($25 on Ebay) that only required a minor change to the mounting flange on the motor. Looks original and I added the red sticker that belongs on the fan motor. The fan motor was missing when I got the truck, but the wiring was still there. To get it running, I had to replace the blown fuse, replace the little can type relay, make the adapter to hold the snap switch to the intake manifold, buy the snap switch, and repair the broken circuit board traces in the control module. It works great and I love hearing it cycle on and off after I park the truck. It usually is finished within about 15 minutes,
ToyotaMatt
Factory Focus-Point Mind-Set Approach
Supporting Vendor
GOLD Star
EAST COAST
Website
vintageteqparts.com
show us the heat sensor you installed on the manifold please Ash , the THERMO sensor
TheHardWay
Ain't as easy as it looks
Las Cruces, NM
Looks like the OEM on my 78.
