I have a '73 fj40. With the addition of some 4" Downey lift springs and slightly longer shackles, I think I need to add shims to get the pinion angles right. The rear axle had a 2.5˚ shim which I kept in place. I took some measurements which are below:
From searches and asking club members, I think I would need an 8˚ shim in front and a 6˚ in the back, which would point the pinions down .5˚ front and 2˚ in the rear.
One thing I was wondering about; will the springs settle/flatten significantly as they break in to change the angles?? They have a ton or arc right now.
Does this sound right?? Just want to make sure I get it right before I bolt it all back together. Thanks!
