Bit of an update.
Got the chassis back. Guys work on the front diff has not the best as the 80 series radius arms didn't even go into the brackets they were designed to go into. He fixed that issue up.
Then I was measuring how much wheelbase I needed to add into the chassis and put the rear axle under the chassis. He was suppsoed to take an 80 series housing, cut the center out and weld in the center of a Nissan Patrol GQ and make it 1630mm wide from face to face. As I am running a Nissan Patrol GU front that is 1630mm I needed the rear to be the same. Anyway, after sliding it under the chassis I looked at it and thought it looked a bit narrow. A few measurements late and the face to face width was now 1560mm in other words 40mm narrower than it started and 70mm narrower than it was supposed to be!.
Thought about it some more and have now given up on the idea of the Patrol center and 80 series outer to give me a full floater area axle and will just use the GU rear I already had. The issue there is the pinion flange is in the center of the axle rather than offset to one side so the driveshaft will now be on an angle, this will also reduce the amount of space on the LHS of the car for a fuel tank. Anway, now I will be running GU front and rear axles so at least there won't be too much of an issue in getting spare axles.
Chassis went to a new local fabricator guy to do the adding in of 9" (225mm) to the wheelbase. The local engineer came down and pretty much laughed at the previous fabricators welding and we have to grind those welds out and re-weld in long continuous welds not lots of spot welds.
Not much has been done with the body as the chassis is needed as we are at that stage where we can almost weld the 2 parts together. So this week the chassis will be done, next week will either be sorting out the rear suspension set up and front shocks and coils or it will be at the panel shop with the body. I reckon panel shop as the rear suspension can wait a bit.
Anyway, some pics to come.
Engine sitting in the chassis, front of the body roughly in position, Toyota 1VD-FTV sitting there with intercooler sitting on the top.
Front view. This things is as wide as a 496CUIN Big block.
Rough rear clearance from x-over pipe to firewall. I think it's about 20mm when all sorted.
Clearance down the side beside the turbo.
