This diff bushing won't cure driveline vibes. Even brand new the bushing flex's quite a bit. Replacing that may help cure a portion of the D-N-R clunk but thats about it.
Driveline vibes are hard to isolate with out removing prop shafts one at a time and test driving with CDL locked. Once you can isolate if the driveline vibe is from front or rear, then you can start narrowing in on the problem.
Lifted rigs: with rear springs different than OEM will effectively create new driveline operating angles- this can cause vibes if the operating angles are too far out of range and this also depends on how worn your control link bushings are. You can pinpoint the over/under by determining acceleration vibe or deceleration vibe to know, but best to always measure to know exactly your operating angles and make necessary pinion angle adjustments with adj. link arms.
Stock rigs: worn ujoints, improperly installed ujoints, non-oem joint, worn yokes, worn slip joint, imbalanced prop shaft, failing pinion bearing 3rd or TC output.
In my experience, just replacing ujoints on these 100's can be hit or miss. If the yokes are worn a little, or they do a poor job installing the bearing caps on the spiders and into the yoke, you can get vibes. Having the propshaft high speed balanced when replacing the ujoints is also a good idea.
Here is "general" reference I pulled from another site on Vehicle Vibration Analysis: Descriptions and Chart
Vehicle vibration can be caused by:
Tire/wheel unbalance or excessive run out
Defective tires with extreme tread wear
Nylon overlay flat spots (performance tires only)
Incorrect wheel bearing adjustment (if applicable)
Loose or worn suspension/steering components
Certain tire tread patterns
Incorrect drive shaft angles or excessive driveshaft/yoke run out
Defective or worn U-joints
Excessive brake rotor or drum run out
Loose engine or transmission supports/mounts
And by engine operated accessories
Refer to the appropriate Groups in this manual for additional information.
VIBRATION TYPES
There are two types of vehicle vibration:
Mechanical
Audible.
Mechanical vehicle vibration can be felt through the seats, floor pan and/or steering wheel.
Audible vehicle vibration is heard above normal background noise. The sound can be a droning or drumming noise.
Vibrations are sensitive to change in engine torque, vehicle speed or engine speed.
ENGINE TORQUE SENSITIVE VIBRATION
This vibration can be increased or decreased by:
Accelerating
Decelerating
Coasting
Maintaining a constant vehicle speed
VEHICLE SPEED SENSITIVE VIBRATION
This vibration condition always occurs at the same vehicle speed regardless of engine torque or engine speed.
ENGINE SPEED (RPM) SENSITIVE VIBRATION
This vibration occurs at varying engine speeds. It can be isolated by increasing or decreasing the engine
speed with the transmission in NEUTRAL position.
VIBRATION DIAGNOSIS
A vibration diagnosis should always begin with a 10 mile (16 km) trip (to warm the vehicle and tires).
Then a road test to identify the vibration. Corrective action should not be attempted until the vibration
type has been identified via a road test. During the road test, drive the vehicle on a smooth surface. If vibration exists, note and record the following information:
Identify the vehicle speed range when the vibration occurs
Identify the type of vibration
Identify the vibration sensitivity
Determine if the vibration is affected by changes in vehicle speed, engine speed and engine torque.
When the vibration has been identified, refer to the Vibration Diagnosis chart for causes. (see below)Consider correcting
only those causes coded in the chart that are related to the vibration condition. Refer to the following cause codes and descriptions for explanations when referring to the chart.
TRR—Tire and Wheel Radial Run out: Vehicle speed sensitive, mechanical vibration. The run out will not cause vibration below 20 mph (32 km/h).
WH—Wheel Hop: Vehicle speed sensitive, mechanical vibration. The wheel hop generates rapid up-down movement in the steering wheel. The vibration is most noticeable in the 20 - 40 mph (32 - 64km/h) range. The wheel hop will not cause vibration below 20 mph (32 km/h). Wheel hop is caused by a tire/wheel that has a radial run out of more than
0.045 of-an-inch (1.14 mm). If wheel run out is acceptable and combined run out cannot be reduced by repositioning
the tire on wheel, replace tire.
TB—Tire/Wheel Balance: Vehicle speed sensitive, mechanical vibration. Static tire/wheel unbalance will not cause vibration below 30 mph (46 km/h). Dynamic tire/wheel unbalance will not cause vibration below 40 mph (64 km/h).
TLR—Tire/Wheel Lateral run out: Vehicle speed sensitive, mechanical vibration. The run out will not cause vibration below 50 - 55 mph (80 - 88 km/h). Excessive lateral run out will also cause front-end shimmy.
TW—Tire Wear: Vehicle speed sensitive, audible vibration. Abnormal tire wear causes small vibration in the 30 - 55 mph (88 km/h) range. This will produce a whine noise at high speed. The whine will change to a growl noise when the speed is reduced.
W—Tire Waddle: Vehicle speed sensitive, mechanical vibration. Irregular tire uniformity can cause side-to-side motion during speeds up to 15 mph (24km/h). If the motion is excessive, identify the defective tire and replace it.
UAJ—Universal Joint (Drive Shaft) Angles: Torque/vehicle speed sensitive, mechanical/audible vibration.
Incorrect drive shaft angles cause mechanical vibration below 20 mph (32 km/h) and in the 70 mph (112 km/h) range. The incorrect angles can also produce an audible vibration in the 20 - 50 mph (32 -80 km/h) range. Caster adjustment could be required to correct the angles.
UJ—Universal Joints: Engine torque/vehicle speed sensitive, mechanical/audible vibration. If the U-joint is worn it will cause vibration with almost any vehicle speed/engine torque condition.
DSY—Drive Shaft and Yokes: Vehicle speed sensitive, mechanical/audible vibration. The condition will not cause vibration below 35 mph (56 km/h). Excessive run out, unbalance or dents and bends in the shaft will cause the vibration. Identify the actual cause and repair/replace as necessary.
WB—Wheel Bearings: Vehicle speed sensitive, mechanical/audible vibration. Loose wheel bearings cause shimmy-like vibration at 35 mph (56 km/h) and above. Worn bearings will also produce a growl noise at low vehicle speed and a whine noise at high vehicle speed. The wheel bearings must be adjusted or replaced, as applicable.
AN—Axle Noise: Engine torque/vehicle speed sensitive, mechanical/audible vibration. The axle will not cause mechanical vibration unless the axle shaft is bent. Worn or damaged axle pinion shaft or differential gears and bearings will cause noise. Replace the defective component(s) as necessary.
SSC—Suspension and Steering Components:
Vehicle speed sensitive, mechanical vibration. Worn suspension/steering components can cause mechanical vibration at speeds above 20 mph (32 km/h). Identify and repair or replace the defective component(s).
EA—Engine Driven Accessories: Engine speed sensitive, mechanical/audible vibration. Vibration can be caused by loose or broken A/C compressor, PS pump, water pump, generator or brackets, etc. Usually more noticeable when the transmission is shifted into the NEUTRAL position and the engine speed (rpm) increased. Inspect the engine driven accessories in the engine compartment. Repair/replace as necessary.
ADB—Accessory Drive Belts: Engine speed sensitive, audible vibration. Worn drive belts can cause a vibration that produces either a droning, fluttering or rumbling noise. Inspect the drive belt(s) and tighten/replace as necessary.
DEM—Damaged Engine or Transmission Support Mounts: Engine speed sensitive, mechanical/audible vibration. If a support mount is worn, noise or vibration will occur. Inspect the support mounts and repair/replace as necessary.
ES—Exhaust System: Engine speed sensitive, mechanical/audible vibration. If loose exhaust components contact the vehicle body they will cause noise and vibration. Inspect the exhaust system for loose, broken and mis-aligned components and repair/replace as necessary.
VIBRATION TYPES
Mechanical
Audible.
Accelerating
Decelerating
Coasting
VIBRATION DIAGNOSIS
