I feel that may not be the carb, sounds more to me like miss.
Check each header tube temp while running with an IR thermometer or....
Pull each sparkplug wire one at a time...
You know the drill.
Check all around the intake and carb base with brake clean to find leaks....
You know the drill.
You know the drill.
Hooked up the MityVac to the carb spacer and everything checked out as it should. Low on the vacuum scale here at sea level but in range
I could not tell if I was in the “poor spark plug gap” area with +1 or if that was just vibration so I pulled all the plugs. Again. Regapped them to closer to the DUI spec range of .040
While I was in there I broke out the timing light and checked the signal on all 6 wires.
Idle was at 550 with the timing at 7*
DUI recommends up to 13* so I bumped the timing. Idle purring at 650 now.
Retested the vacuum and picked up a few
Took it for a final (hot as hell) spin up the road and it’s running great. I think I’ve dialed most of what has been ailing me out.
I still have a bit more gas fume at idle than I had before. Idle is mostly smooth.
I checked the headers after the drive and #6
Was still 150* cooler than the hottest pipe. No idea what that is about.
Last thing on all this. Checked the compression during all this and it’s a steady 120 across all cylinders. This is a rebuilt (of unknown quality) 2F with about 10,000 miles on it. Never has smoked or used a drop of oil.
With the engine running, squirt starter fluid at the base of the carburetor and around each place where the manifold attaches to the cylinder head. Listen for a stumble or change in RPMs it will help you zero in on any leaks.
I would do a leakdown on 6. I know compression looks good but I would still do one. Do one cold and another one at full run temp. The carb is common to all cylinders. If you had a rich issue there you should have more than one cylinder running rich. Besides on inline engines the fuel tends to lean out at the ends of the manifold.
Yeah. I exhausted my 1/2 can finding what I thought were the leaks in the booster hose and that pipe fitting.
I quit for the day...actually for a few days.
Carb has been off twice to put new gaskets on. Thought that was the culprit. Changed the the booster bung and hose. Thought that was it. Resealed that bung pictured above.
Still don’t understand how a leak in the intake would make #6 miss
