jfz80
Cruisin’
Enabler.
Jump on in Jon, it all worked out for Alice
For the deck surface, gasket scraper, then scotch brite pad on die grinder (do NOT focus too much on one area), then finally (if you have one) a stone to make sure it's flat. That should leave you with a good block deck to put the head on. Use plenty of fluid to wash the garbage down into the oil pan.
Haven't had time to pull the oil pan, etc. but will tomorrow.
Question - the distributor appears to be stuck. It rotates but won't pull out (I did remove the screw in the slotted section). I've searched and read up on tapping it out from below, but how hard can I tap? I've tapped with relative restraint via a wooden dowel but that's it. Looking for some direction. @Rice @GLTHFJ60
