Project Canyonero - GMC i5 swap into '92 FJ80
Greetings all!
I joined IH8 because Land Cruisers are rad and to share this project. I’m calling it the Canyonero project. Dropping in a 2006 GMC i5 3.5 motor and transmission from a 2WD Colorado Canyon. (I got Canyonero from a Simpson’s episode) I hope some of you stay tuned as I update progress start to finish. I also hope to get some ideas, suggestions and source needed parts from other members with the combined knowledge and experience in this forum.
I know there are a lot of different options on how things should be done, but if you don’t have anything good to say on my thread, please kindly move along.
I have owned my LC for almost 9 years. It had 200k on it when I bought it and have only put 24K since then as it was our third vehicle and really only used it for camping, exploring, mountain bike/ snowboard shuttle or when our family of six needed to go somewhere together. I love our LC. I love how it rides and its toughness. What I don’t like is this thing is a slug and has horrible mpgs. The GMC motor not only has a lot more power and torque, it is also 600 pounds lighter. When done, I should be able to get 18 city / 23 hwy mpgs. Stock I was getting 9 and 11.
Before we pulled the motor, we recorded some data. Recorded weight and few passes recording time and speed/rpm. Also some runs pulling a 4460 lb. boat up a 6% grade. Motorweek reported a new 1992 LC had a 14.5 time 0-60 mph. Mine with 224k miles put down a painful 21.7 avg.
Stock curb weight is 5,060. w/boat: 9,800 (½ tank fuel)
Avg. time:
60 ft. – 21.7
330 ft. – 10.2
1000 ft. – 19.2
¼ mile – 22.7 @ 2100 rpm (4th gear)
0 to 60 mph – 21.7 3000 rpm in (3rd gear)
(average of 4 passes ea.)
Towing boat: uphill, 6% grade – avg. 45 mph, 2nd gear, 3600 rpm
40-50 mph level road time: 11.2
Anyone looking for a stock ’92 FJ80 motor and/or trans? I no longer need it. The motor/trans run well.
Parts I need (so far) from a FJ80:
Stock trans cooler and bracket
Stock A/C condenser
Any help with needed parts would be GREATLY appreciated!
I have uploaded a few albums of the progress so far.
I only get shop time once a week, so progress will be a bit slow.
New motor
Jan.15th - Pulled the motor and started making a list of parts to reuse/not use.
Jan.22nd – Test fit the transfer case to GMC trans. w/ new adaptor shaft.
Remounted the stock transfer case, cut the motor mounts and mocked in the motor/trans.
Looking at what’s going to clear and what’s not. The oil pan clearing the front drive shaft is the biggest issue right now. Hopefully, the new Hummer pan will work. Will not need to reroute the brake lines.
Jan.29th - Started looking at the wiring. Pulled temp sensor and oil pressure sensor from stock motor. Some other stuff I am forgetting.
Feb. 7th – More wire play. Pulled the stock gas pedal. Made a new bracket for the GMC pedal.
flying by wire now
Pulled the stock fuel pump. Modified the pump bracket to fit the GMC pump and to make sure it sat down in the tank far enough like the stock pump did.
Mounted the stock oil pressure sensor by tapping into an aux port/plug on the motor.
More to come. Starting back up Feb.28th and looking to make better progress in the next coming couple weeks.
Jason\m/
Greetings all!
Avg. time:
60 ft. – 21.7
330 ft. – 10.2
1000 ft. – 19.2
Stock A/C condenser
New motor
flying by wire now
Jason\m/
