Time to keep the parade of stupid threads marching along...
After reading several threads on the subject, I decided to try my hand at centering my steering wheel (currently pointing toward 10-11 o clock). I had sprayed penetrating oil days in advance and got the collars completely loose without issue, but the problem is the link itself. All I succeeding in doing was crushing the grease boot on the my pitman arm and making the whole assembly, including the steering damper feel loose without moving the drag link one iota. After using a BFH to try and loosen things up, I tried holding the passenger side drag link end while loosening up the drag link, but no luck. For the time being, I had to walk away after dousing the threads with penetrating oil. It's worth noting that I didn't notice any bent splines, but I'm not a trained mechanic, either. For now, I'm trying to figure out what to do next and pricing out a urethane pitman arm bushing. Anything I'm doing wrong or any suggestions are completely welcome.
EDIT: I think I'm using some incorrect terminology. If anyone can tell me what the name of that bushing/assembly on the pitman arm is, I'd appreciate it. I was hoping to drive the thing this weekend, but I can't imagine it's smart with that grease boot popped like a zit.
