Is there anyone who is knowledgable on connectors? I have spent the day on google, allied, mouser and other electronic suppliers looking for the connectors. I have sourced a 3 dial controller and they are going to leave the pigtails on. I would really like to do this without cutting wires. There are 5 connectors coming out of the navigation system that will be used to convert the vehicle to non-nav. They are Toyota Part #s
90980-11469
90980-11391
90980-11392
90980-11913
90980-11350
I need to find a mating connector for all of these. If I can get these mating connectors I can wire the pigtail to them and plug into the vehicle. I think I have found the following connectors
90980-11469 looks like it may mate with 90980-11504. This is a Toyota part. I am going to order the part and see
90980-11391 Converts to TE part number #917981-1 and it shows a mate of 178764. This is a terminal block similar but not identical to what we need.
90980-11392 Converts to TE part number 917989-1 and it shows the same 178764 mate. Here is a photo of this block. It is remarkably similar to the back of the donor and the nav ac amp.
Mate that is shown for plugs won't work:
Here is what the back of my ac amplifier/ nav unit looks like
I have no leads on the other 2. In its' simplest form this conversion is taking 5 connectors and wiring into 4. There are an additional 6 connectors on the vehicle but the 4 for the MFD will be left abandoned in the dash, 1 going to the DVD player will be abandoned and the last one will be used for our new stereo install by using a Metra harness. This could be done without cutting vehicle wires if I can source matching connectors. Red jet reported that a repining is not completely possible because some of the connectors have wider terminals and there is some issue with not quite enough wire to easily access. I have considered pulling the mating sections from my current nav unit but the mating connectors are soldered into the system so I do not think I can use a crimp terminal to attach to them. I have tried some plug dealer websites and sent some emails but nothing. Anyone who can provide any information would be great. I spent an hour or so with my FSM and the pin out guide. I had to add the power antenna wires to the diagram but the rest matched up to my 2002 FSM. This looks like a straight forward swap I just want to do it by tapping into the existing Toyota connectors if possible. Gonna spend a few more days on google while I am waiting the arrival of the donor controller. Thanks
