Power steering resivor to pump o-ring
Corvallis OR
On the line from the reservoir to the power steering pump, there is an o-ring where that line goes into the pump. I got the metric o-ring from the hardware store that seemed to be the right size, correct diameter and the cross section of the o-ring fills the groove, but I can't get it into the pump. Is that a special Toyota o-ring or do I just need to get a thinner o-ring?
Did you try putting some lube on that O ring before you tried to install it in the pump? If not try lubing it with a little ATF, then try installing it.
Lube didn't help. I think I need a smaller cross section o-ring, but I'm worried it will be too small and leak.
This one? I used regular metric o-ring and re-assembled with grease. Needed slight force to get back in. No more leaks.
Ux4QH9zdeCFL8Q84LLbbcSqDVhb3nWgETtzYmHC6cZhh8B6dLwQkILacmOw92zDPQoDgQudzknMM112l963AzHFsRq_eZeuVqiMxAoRxVbto2lo08JQs_3GVzxe5TDVeMSGeHS0mgmIHiBR5Ocx95oKsm-v_EskcSpGuosUlThOnP190bRFSmgYmAudtd4jkQCUD6CYiYNvQuYCSfIAxPsGXzlbVDvc1lHtxBpJG-ETHTKYbZIiJim8cnQr4y8mvFWn4VqRZtuTEbqw1pnzlb2dGYcCtoIO0JqvRA9hkLB-0v8Hb8nCo34afDSY4U2auzJWDRFc1Qh0dC1QAnh2YT0uy-9ISAimWsdUtYx_EgZ7-CDGPBQ9_h_Z5Zman_CDv8ApsSXPxxOyIsA7phttR1iqygFuIBkY-gVRz7ZBo4mKt8MGvOnby0y4mMkp_FiilDVFdpsUI0n6rsAnivbwJa1g3NBdOzliyJsGYW-OH2Tgvd-F0LoHFLA3Sxn1TiF8pVLtt48uhHQ1f2KptkencLCCQc87TlS_g5lhRpWzjjvhs7QmE6Vyq4pjTBU5shWJt-WtoQ4s6yhWx-pQFjwq4UPmP4aYbjjKHPM_8T9N-ayuctrzUgTn1g05MeNenL_QzOf2840RDLWsIf5GCM22Kg7ZPjwH4ntGLN0AhneBls-q34duCi7f55oA5Gn0UcvE_FWe1c7RGkkoKbzfPhQ=w600-h1065-no
Don't forget to use grease, otherwise you will most likely crush the o-ring.
It's not crushing it that he needs to be worried about, it's nicking or cutting the O ring if he tries to install it without lube, and if you cut that O ring, it WILL leak.
Lube, it's all about the lube, baby......
