Power steering pump leaking
Hello All,
On my 91 LC, the rear of my power steering pump in leaking, anyone repaired this before and any tips, is it repairable or just replacing.
Also I am still looking for info if an 80 and 100 seat are interchangable, if anyone with both if they could try a swap or measuring it would be appreciated.
Thanks
If it's the pump just replace it - now if it's the box you're in a different ball park all together ($95 for re-build kit - $2k for new box :eek: ). Make sure it's not the hose from the res. before you spend the money though - cdan can hook you up w/ an OEM pump.
Tucker
try dumping in some of that stop leak additive. I had to dump in 1-1/2 bottles but it actually worked. big surprise. it wasn't my pump that was leaking though, it was the steering gear box where the shaft enters it.
Thanks, I can see it coming from the rear of the pump, you can see it slightly leaking onto the A/C compressor. There is a round circle on the back of the pump and it is coming from the bottom of the circle. Thanks for the replies
rebuilt a 93 3 times...long story...check with Dan on a kit
Hey Dan, I guess I need a kit, would love a parts list if you have one handy, 91 LC
You probably need to pm (private message) him.
I am still dealing with a leaky power steering box. Mine was leaking from the adjustment screw/lock nut on the top of the box. Apparently the tightening nut that locks the washer/gasket down had come loose and that's what caused the leak. I tightened everything down, but i still get a groan every so often.
concrete, make sure the groan isn't coming from your steering stabilizer. I was getting a loud groan on left hand turns only. I thought it was my steering box, but it turned out that the stabilizer was rubbing it's outer shell. I stuck it with a gob of grease and the sound is gone.
