Power Steering Lines
sark
42601-60262-03
New England
Seems like there's not much discussion on 1HZ power steering lines. Mine are leaking and causing other problems, and Amayama reported NLA from supplier.
Anyone have a part number replacement for 44410-60280? Alternatives? Didn't think this would be an issue to find.
Found this listing on ebay from Japan.
I took all of my hose assembly to a local hydraulic mob and got fresh hoses, clamps and crush washers. Ended up a whole lot cheaper than buying new.
As previously shared, you may want to check local shops that can fabricate replacement hoses. This option is available in Georgia, so it should be in New England too. They can use your existing hoses as templates.
I keep meaning to pull the plug on a set of those lines but they're usually over $400 and they can be made locally for less than half that. Head downtown, usually near the airport in my experience, and find the shops that service trucks and you'll find people that make custom hard and soft brake and power steering lines.
