Power Steering Fluid Question?
San Diego
Website
youtube.com
FSM says Dexron III
Search is show various opinions, some posts years and years old.
Seen @bloc and I think some others saying it’s backwards compatible. So many options. Head hurts.
What’s the current consensus on WHAT FLUID??
System will be getting an entire flush/replacement
Thanks
Can't necessarily comment on what the consensus is for the PS fluid. But i like to swap out the fluids for full synthetics (diffs,tranny, PS). For the PS I flushed out what looked like original fluid at 85,000 miles when I picked up my 200 and went with full synthetic Redline D4. Old fluid was dark and nasty looking after 6 years of use. Now 5 years later I am now at 140k and the Redline D4 fluid still looks nice and cherry red, basically new. Doesn't look any worse for the wear.
I've done a few times on my 2018 LC. Use Mobile 1 ATF. drain, fill, drain, fill. On jack stands. 3 full turns. Easy
I basically followed the procedure shown in posts 36 & 38 here.
I don't remember this being the exact thread I referenced, but the procedure looks the same.
I used the Toyota 00718-ATF00 fluid shown above
Thanks man. It wouldn’t show up on Amazon until I used that part #
All good
Thanks
Not sure how much it is on Amazon, but you can get it locally at Norm Reeves for ~$11 / qt (order online and pick up)
I use Idemitsu PSF. Per CCN (all hail his name), that's what he says it comes filled with from the factory. I don't know if it's sythetic or not, but can say that it looks about the same as what comes out (aside from a more honey vs. syrup COLOR) - consistency is the same.
I haven't been in a Napa that didn't have it in stock. I'm a BIG fan of HPL/Amsoil, but can say the availability and known compatability with itself has lead me to just keep it simple.
Damn…. It’s half the price locally…. That’s bizarre. I’m lazy so perfectly fine sometimes paying a few bucks more for Amazon, but this will be a dealer trip!
Thanks for the info
Damn…. It’s half the price locally…. That’s bizarre. I’m lazy so perfectly find sometimes paying a few bucks more for Amazon, but this will be a dealer trip!
Thanks for the info
I found that you have to order online for that pricing. They won't honor that price if you try to order in person (at least they didn't for me). In store and online sales are a different entity apparently. I just ordered online then picked up an hour later. May want to call first to make sure they actually have them in stock.
That's been my experience as well (Koon's Tysons Corner, VA).
The FSM says to use ATF. I was thinking about it and I suspect the fluid doesn’t really matter so long as it’s not hygroscopic and can mix ok with any existing fluid. The fluid isn’t really lubricating anything to my knowledge it’s just used to apply pressure to turn the tie rods. You could probably purge the system and refill with motor oil and it would work ok
My last ps flush I had purchased 2 quarts atf t-iv. @bloc had posted that is what the fsm recommends. Ccn did my ps flush. He used it without issue.
I noticed that under maintenance section of the Toyota dealership they had specific power steering fluid. So I purchased for the next flush.
Post what the new PSF looks like from Toyota.
It does lubricate the pump internals to an extent (but not the bearings, which will typically fail before the pump internals on a well maintained system. Also, the input shaft and other parts of the rack.
Here is my opinion:
As long as the fluid meets the standards that Toyota specifies, you’ll be just fine. I think the main concern is seal and hose compatibility. You can put synthetic magic fairy fluid in it or just standard TOYOTA ATF fluid—it really doesn’t matter a damn bit. I think the main concern is seal and hose compatibility.
As long as you replace the fluid at regular intervals, the system should last a long time.
In addition to keeping the fluid in decent shape, the biggest piece of advice I can give is to regularly check those steering rack boots and replace them the moment you see a puncture/tear. They’re very cheap and easily replaceable parts keeping a very expensive and relatively difficult to replace part alive.
Interesting, was not familiar with this and will do some more digging about it
Thanks
