Potential HJ61 5spd touchy throttle fix
I used a ‘dash pot’ to reduce the jerky throttle from idle in my hj61. It helped greatly as it slows the injector pumps return to idle. It still is touchy (which I quite like for some reason), but no where near as touchy as it was before....
I can take photos if anyone is interested...
Definitely interested
Here is the Dash Pot... I got it from the wreckers and made up a stainless bracket...
It is only used for the final few mm of the throttle returning to idle.
Sorry for the bad photos!!
My truck had really touchy throttle response since I got it. Came to realize that there was only one, old spring where there should be two. Ordered NEW ones from cruiserworld, and holy $hit it’s like driving an 80 now...so smooth. BONUS TIP: getting the second end of the spring mounted on the rod was a PITA! Until I used a small zip tie head to hook the second end of the spring, then mount the forward end, then use that zip tie to pull the spring out of the rubber hose and onto the second rod.
I know I´m writing to a old thread.
Recently bought a HJ61 with super sensitive throttle. Had a stiffer spring made and its much much better, almost good :-).
Originally there are 2 springs and both are inside of a rubber hose. I think the rubber hose is there to delay the action of the springs, should work as a damper for the spring action. You have to pull the spring out from the rubber hose or push it into the hose.
I have 2 new springs on order and will do a writeup after installing them.
I know its becoming a old threat. The biggest difference for me as of now fixing the sensitive throttle is I got a new leaf springs from OME. the softest. The car is 100% better now regarding jumpy throttle, I would even consider it cured ( with the stiffer spring on the throttle body to ). So part of the problem in my case where way to stiff leaf springs giving a jumpy ride affecting the throttle through the pedal.
yet again reviving this thread since all the old posts are old and links are broken.
Can anyone post a link to correct springs or fix for this?
This one works, but initially it went to a 404 page, just wait a few seconds and it jumped to the website.
Wow. It's going to cost me 100 bucks to get these to me lol. I may try other random springs first but I do appreciate this as a last resort.
Group buy?
I'd be down if we can get enough people. How's that work with everyone being all across the US though?
Shipping them in the US is $8 in a USPS box. It's that leap over the ocean that's rough
Denso part nr for that spring is,
091041 0370
are you sure about that shipping cost? Maybe overnight delivery was selected? There is no way that I paid even a third of what you quoted. You may want to reach out to them and verify shipping cost of two lightweight springs to the states.
It's possible I had something selected or the system was glitching. I'll have to double check.
