Any idea what switches Toyota ever put in those slots, maybe in other markets? I've never seen pics of dashes with OEM switches in that location.
Subtank (Oz), rear fog lights (Euro)..... Can't think of anything else.
Ian ~ having just had the bezel off of my 80 lastnight,
i have a sneeky suspiscion that the auberin gauges
should fit the factory openings in an 80. You might have to
remove some of the "wood" trim, so choose your
spot accordingly. double check the specs and
measure.
How are those mounted? Screwed into the pillar?
wildsmith said:This is an Arduino based touch screen device I made to do gauge duty in my 80, did the same thing for the 100 I used to have. Does various temps and pressures, voltage/split charge, speedo correction, trip meter. Still got to fit the EGT probe and oil pressure sensors but the boost, coolant temp and coolant loss sensors are working.
I need details on that! Please?
measure.
Screwed directly in. It worked out well I think, they are right there in front of your face, great visibility but not in the way. ATEB in Burnaby BC installed the gauges as they were required for their power rod tune. I can ask if anything else was used other than self-tapping screws if anyone would like more info.
Doesn't use OBD, that's not an option on the 1997 80 I'm in nowx4!
Does the truck need to have OBDII to use one of these? Your an 80 owner again?
Doesn't use OBD, that's not an option on the 1997 80 I'm in nowThere's a longish thread about it here http://www.landcruiserclub.net/forums/showthread.php/41651-arduino-amp-touchslide starting with the one I built for the UZJ 100 I used to have. Happy to answer questions about it.
EGT and Boost-
