Don't stress it honestly one of the easier jobs i've done on it. Yes it would suck on the side of the road when the engine is hot but in the garage no sweat
Agreed...I was not looking forward to this last weekend...in the end, it took me longer to find my hose in my travel bag, pull the front wheel, and heat cycle the truck to top off the coolant than to change the hose. I did mine through the wheel well with no unexpected issues.Don't stress it honestly one of the easier jobs i've done on it. Yes it would suck on the side of the road when the engine is hot but in the garage no sweat
Agreed. The key is patience. If you get frustrated, take a break. It's almost surely going to take multiple tries on removal and reinstallation no matter what (even with specialized tools), so just plan on taking your time.Don't stress it honestly one of the easier jobs i've done on it. Yes it would suck on the side of the road when the engine is hot but in the garage no sweat
Thanks for this @KernalA couple months ago I replaced the heat control valve on the firewall as it looked like it was about to burst. I knew the PHH needed to be replaced (but wasn't leaking yet) and also knew the valve cover gasket seeped a little bit along with the spark plug tubes, and I was about to go out of town on a long trip so figured I'd wait until summer.
But then the PHH let loose so had to dig into that, and then decided might as well fix the valve cover gasket and seals. But in doing all that I had to remove the heat control valve from the firewall all over again and busted my knuckles and wasted a lot of time trying to remove that PHH bottom bolt before removing the valve cover.
So doing all those PM's at the same time would have saved time and effort if done in this sequence:
Remove Heat Control Valve and attached hoses then unbolt the main engine harness from the firewall
Remove Valve Cover (along with Throttle body)
Remove and clean/replace EGR valve while you're in there
Remove the PHH water heater pipe sub assembly (87209-60281)
Then reassemble (with new parts/gaskets/seals) in a reverse sequence.
An added benefit while the Throttle body and Valve cover are off you can clean up the varnish, carbon, and crud that builds up on/inside the Valve cover (and internal oil baffle), and the Throttle body butterfly, IAC port, and vacuum ports as well as the EGR tunnel in the upper intake plenum which is often completely blocked with carbon. FWIW
It’s not stupid if it works! Great tip!Stupid tip to get the lower bolt back in - I had heater valve, EGR and Upper IM out of the way. Taped the bolt head to a long 14mm ratcheting wrench to keep it in place until the threads got some traction.
Thanks a lot for that rapid response. I tempted to go that way too. Cheers.either way works tons of posts/threads on both
I didn't do the bypass and put the hard pipe back in
I think I was basically following a comment you had made elsewhere in my own effort. I am pretty proud of the refresh on my father's '94 we did before taking it out to my daughter. There is a ton of wisdom from this site in nearly every part of the project.I did this by laying some padded mats I made from styrofoam and cardboard on top of the engine - I laid on my stomach like Superman and looked down the back of the engine to do this
