Sorry for the simplistic technical post, and I have searched with master Google, where can I find the foam insulation? Also for the valve side.
Thanks.
Thanks.
The foam comes with the hose, which I agree looks to have seen better days. That hose on my 98 from AZ was hard as a rock.
From 1/1998-5/2005:
Hose, Ventilation - 1226150050
Foam for PCV - 1223650010
Foam for Other End - 1223550010
Clamps x2 - 9046715021
@2001LC, Not sure I am understanding your post above. I the foam around the PCV important to have? I have never changed out the PCV and grommet in a hundy and about to now. So deciding on how important the foam is as I get into it. Thanks
I replaced the valve and grommet in our 2006 we used to have and that foam was fine.
Did you notice any difference in engine, mpg, etc. ?
The foam isn't all that important, but nice in stick with OEM design. I just clean them and replace. I really don't know what they're for. But on the 200 series they use more foam around top of engine. Which is to muffle the sound.
The rubber grommet that PCV valve set, in the 98-02, is very important. It hardens and shrinks over time. This allows dirt & fluids in the head through the head cover, air leaks around it and PCV valve as well. "A vacuum leak". This reduces vacuums suction of crank case gases, allowing pressure to build in crank case. It also will increase air into intake, causing engine to run lean. You get a higher than normal fuel trim % reading (rich mixture) from this, as system compensates by adding more fuel.
Same applies to the hoses, that is, they create a vacuum leak.
The rubber grommet, is better changed sooner than later. Why, well leaks as valve get lose from the grommet shrinkage. The rubber hardening make difficult to get out of head cover, without dropping pieces of hard dry rubber into head. Then you need to used needle nose or forceps to fish out of head.
The design was changed in 2003. They removed the foam and grommet. Then added threads to the head cover and PCV valve. This is a much better designed IMHO. It does not allow dirt & fluid into head, nor vacuum leak at point it connects to head cover by threads. But just like the 98-02 both hoses need replacing and PCV valve inspected and cleaned regularly. The valve itself needs less cleaning if synthetic oil is used and changed by the book.
03-07 valve is very hard to remove. Because Toyota uses threads locker threads of valve. I use a 12" (large) crescent wrench and get a very tight fit on nut portion of valve.
