Transfer case seal is leaking at parking brake drum. I bought the double seals and will be installing in the speedo housing. I also bought the speedi sleeve and wondering how far in I should install it. It doesn't look like it's going to cover the depth of both seals. To me it makes sense to make sure the inner seal rides the speedi sleeve. Any advice on this?
Also, take a look at the drum shaft. At first I thought it was scored badly in one spot, but actually some PO has turned the shaft and pressed on another piece. Has anyone else seen this? I'm slightly worried it could compromise the strength of the shaft where they meet.
