After 223,793 miles I got my first "needs maintenance" light. Just the P0420 code "catalytic insufficiency bank 1".
First I measured the temperature increase across each cat and they were both 70 deg F, so I'm thinking not the catalytic converter. Next I tested the alternator output and at the battery posts it's only 14.0 volts. I'm sure last time I checked it was 14.5 volts. Wires to O2 sensors look sound. Gas cap was replaced a couple of years ago and "looks" OK. Not pressure tested.
Just had timing belt and water pump done and since then serpentine belt not perfectly aligned. It moves side to side with a slight sound on each pass."
Could that job have broken a vacuum hose?
Does this "say anything" to anyone?
Mike
PS My old 80 must go. Mechanics fine but interior a chicken coupe!
Mike
