PM me if you guys need help with the EGR system. I just passed CA smog with my modified system.
Saved me a ton of headaches. Thanks so mich for this write up. Doing all of this over the weekend.Forgot to add:
Pic of cleaned port that was blocked, compare with earlier blocked port pic.
This lines shouldn’t keep it from starting, they’ll just make it run like crap if theyre hooked up wrong. Are you positive nothing else was knocked loose, or maybe a connector not seated? I’d go though the standard troubleshooting process to determine which of the big three (fuel, spark, compression) you aren't getting. Once you’ve ID’d that, you’ll have an idea which way to go with troubleshooting.So this weekend I did this fix pulled the manifold/throttle body cleaned both. Replaced all vacuum lines and VSV. Put back together and the truck won’t start. It turns over like it wants to but won’t fire to life.
I have some questions on some ports on the manifold itself. There is one by the EGR sensor connector and one on the underside of the manifold by the VSV (here in this pic I have the VSV hooked up to it) what are these for and where do the lines from the go to?
And here is some pics on my cleaning job
View attachment 3439592View attachment 3439591
I did a ton of swaps this weekend.
Radiator
Blue hub fan clutch
Water pump
Fan
Upgraded alternator kit from Landrank
New fuel filter
VSV
All new water and vacuum lines
Was highly anticipating hearing this thing run with all the new gear but huge fail when it wouldn’t fire. Anyone have any ideas? All vacuum lines are correct bolts torqued everything seems in place. The only things in question are those manifold ports.
Check the connection on the back of the alternator or battery wire to the alternator.So this weekend I did this fix pulled the manifold/throttle body cleaned both. Replaced all vacuum lines and VSV. Put back together and the truck won’t start. It turns over like it wants to but won’t fire to life.
Radiator
Blue hub fan clutch
Water pump
Fan
New fuel filter
VSV
I was also thinking this. Landtanks kit provided an upgraded fusable link but I felt if this was the culprit it wouldn’t even turn over. I have visually looked at those plugs but I should ohm it out now for continuity. Unfortunately the grounds are connected I wish it was that simple.Check the connection on the back of the alternator or battery wire to the alternator.
That's the primary thing you've changed that may stop start.
Also, check the plug above the distributor, it has been known to have a broken wire there, especially after messing with the intake and other things in that area.
I'm guessing you forgot to plug something back in or reconnect a ground wire (such as from the coil to the engine block lift lug)
So since I had everything torn out I didn’t bleed the pressure to the fuel lines by running the engine and unplugging the pump before removing the filter. I lost a little extra fuel but no biggie. As for hearing the pump running I listened for it with the acc on and nothing but figured it may only run in the ignition on positionMy guess would be you're not getting fuel after the fuel filter replacement. See if your fuel pump is pumping, you should hear it. If not check fuses. Make sure you are getting pressure to the rail.
It might sound crazy, but the truck will turn over with a fusible link bad. There is a procedure in the FSM for diagnosing the ECU startup with regards to the fusible link. I have a 94, and the process differs in the 95 and up. Do you have the FSM?I was also thinking this. Landtanks kit provided an upgraded fusable link but I felt if this was the culprit it wouldn’t even turn over. I have visually looked at those plugs but I should ohm it out now for continuity. Unfortunately the grounds are connected I wish it was that simple.
The fuel pump only runs when the engine is turning. It will not pump fuel with the key in the ACC position. I also recommend you get the FSM and start at the beginning of the troubleshooting section. You'll find the problem.So since I had everything torn out I didn’t bleed the pressure to the fuel lines by running the engine and unplugging the pump before removing the filter. I lost a little extra fuel but no biggie. As for hearing the pump running I listened for it with the acc on and nothing but figured it may only run in the ignition on position
i do ill have to start reading i suppose. since im sitting here gripeing already ive got a gripe on the FSM... why are those damn pages so easy to tear out!?! a gust of wind will blow it right out of the book!It might sound crazy, but the truck will turn over with a fusible link bad. There is a procedure in the FSM for diagnosing the ECU startup with regards to the fusible link. I have a 94, and the process differs in the 95 and up. Do you have the FSM?
tried it didnt work. srayed a good 8sec burst through the TB with the throttle open then slipped the air intake back on.... no luckYou could spray some starting fluid in the intake and see if it fires. It still sounds like you're not getting gas to me.
