Cleaning the sensor...what was used on yours NLXTACY?
excellent!! Thanks!![]()
BTW wondering if I should do LANDTANK's sleeve now
I would do the sleeve for sure. It does seem to improve things some.
If you have an OBDII scanner post up what the short term and long term Fuel trim values are. You will likely need to run the truck up to temp first. When added together the acceptable range is -30% to +35%.
That clears up the question I had with the FSM.
The problem is while you are idling. While idling the FT% total more than +30% however they are at 11% while driving.
Do you have access to a wide band sensor. If the AFR is 14.2 while idling then the O2 sensors are working properly.
The first thing I'd do is check the Air flow rate (AFR) during idle. This should be in Lbs/Min and with an unsleeved housing it should be around .68-.70 lbs /min. If it is then the MAF sensor is reading properly and the issue is somewhere else.
