Sorry I missed that. Is the FPR is still capped?
That AFR reading is slightly lower than what I recorded but not enough to account for the large FT%
I'd suggest sleeving that housing and reattaching the vacuum line afterwards as a first step. The sleeve will bring the idle AFR back in line with the stock sensor.
I posted a series of data logs a while ago here https://forum.ih8mud.com/80-series-tech/347736-obd-ii-data-logs.html
If you look at the unsleeved logs you will see that the AFR is as lows as .63 during idling but the FT% never gets very high with the exception of a non sleeved housing with an attached vacuum line to the FPR.
I wonder if it has something to do with the fuel pump relay being in the low position.
Yup, the FPR is still capped.
I'm going to check the FT on my way to work this morning since I'll be on the hwy for about half hour or so. I"ll get you more data.
