I looked at a friends Isuzu Trooper last week with this code. He has a bad intake gasket. So the more likely the culprit is a vacuum leak somewhere. These trucks are getting on in years and like anything else time is starting to come into play.
My sensor was used... What are you thoughts?
Why not swap your old MAF in and see if the issues are still there. I would really doubt a fuel pump going bad, or a fuel filter that dirty that you would get lean conditions.
Just that if there isn't anything wrong with the connector to the MAF, and there are no air intake leaks introduced anywhere, your sensor itself might be bad or dirty. As Christo already suggested, if tightening the connectors doesn't do it, swap in the old MAF sensor and see if the condition changes. Again this all comes after verifying that there are no air intake leaks. HTH.![]()
How long did it take you to do the fuel sock? I have the stuff here but just have so little time. It looks relatively quick but wanted to make sure.
)IMO this code comes from the system or one of it's components not working consistently and predictably. You're likely looking at a problem in the wiring, bad sensor, bad fuel pump, an air leak upstream of the front O2 sensor, almost anything.
In the case of the bad fuel filter, it was likely restrictive enough so that it didn't flow enough fuel to maintain the fuel rail pressure all the time and when it was low it would yield a lean condition that the ECU couldn't foresee and trigger the code.
If it was a hot day you might consider the fuel pump itself as they can run sporadic when old in that type of environment.
Ok quickie half-ass update:
I've been out of town ALOT and now I'm on my way to the World Cup in South Africa. (Just wanted to brag)
I swapped out the MAF and switched the wires back. Pretty painless. Wife was driving around and after about 70 miles the P0171 came back on. So I'm pretty sure that takes the MAF out of the equation. I also inspected the intake hose again and its still soft~ish with no cracks.
Now while I was gone my wife said that the truck just didn't feel peppy any more and it lost all its power off the line. I chalked it up to her being a needy woman who just wants to complain about every little thing. Well I drove it today and sure enough. It doesn't bog down when you step on the gas, it just doesn't go anywhere fast. Its like I am cruising and not giving it gas at all. On the freeway at speed its totally fine.
So my next step is to do the fuel sock finally and change the fuel filter as well. Even though I just changed it six months ago. Just in case.
Thanks for the update and taking the time to swap in the stock MAF. I realize it's pretty easy to suspect an associated MOD with any kind of problem that might crop up.
It's probably going to be a step by step swapping of parts that finally reveals the problem.
I too was glad to disprove that your MAF was the culprit! Also, since I installed your sleeve my truck hasn't run better!
Good luck
The sock is probably easier to change than the stupid filter. I have both. I will do the sock first and see what happens.
BTW wondering if I should do LANDTANK's sleeve now
So Landtank, is this something we should all be doing on a regular basis (at least those who have your MAF)? Cleaning the sensor that is?
