I'm in! 2007 GX 470. Looking forward to it!
I’m want to purchase one as well, do you have any left?
I would like to buy one ! Do you have any more on the way???
Thanks
Interested!!! I hope I didn’t miss the boat on this. Damn.
This is a must-have. I'd like one too!
A local customer/friend managed to put two mounts on the one bracket. Pretty awesome! Given the various ram mounts available, the possibilities are really endless.
Went to do the install today, and failed. Got all the way to the end, where you remove the 4 screws and the things would not budge. I had prepared for it, knowing that I should use JIS, so I bought a JIS precision set, and the largest one (size 0) would not do anything. I tried to put vise grips on the handle to get some more leverage, but nothing.
Not expecting much, I tried similar sized phillips precision set and nothing. Pretty sure they are at least partially stripped from my attempts, but I started with the JIS and they would not turn. I had seen in an earlier post that a JIS #1 was what was used, but I would be heistant to think there would be so much of a difference between the 0 and 1 that it would allow the screws to turn.
Similarly, when I went to detach the black screws I needed to lock the s**t out of the vise grips around the nut-type edge to get the initial turns going, since the screwdriver did nothing. Once that inital turn was done, it was an easy hand twist. Unfortunately, there was no way I could do a similar thing on the tiny screws in the tape deck. Overall, it was a relatively simple process, but I must have gotten the tightest screw fastenings ever, and am a bit sad I wasn't able to complete it. I may try again with a JIS 1, but not entirely sure if it would even be doable with that.
Was this just two of the angled ball mounts you recommend? Did it require a longer mounting bolt?
I'm using a similar setup but with the double ball mount instead of two angled ballsWas this just two of the angled ball mounts you recommend? Did it require a longer mounting bolt?
Amazon.com: RAM MOUNTS (RAP-B-230-1U Adjustable Double 1" Ball Adapter: Automotive
Buy RAM MOUNTS (RAP-B-230-1U Adjustable Double 1" Ball Adapter: Vehicle Mounts - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
edit: i wouldn't recommend this mount though as it is not sturdy enough for a tablet and phone.Can you post a pic? How does that mount to the media mount and let you mount something to each ball? I can't tell from the Amazon pic.
