Outfitting FJ62 to tow 3500# (5 Viewers)
I hear ya, but a 5.3 swap can be done for under 10k, if you do it yourself.....but thats a BIG if
I’ve had friends try. Paiging @Kleatus
An LS swap isn’t cheap even if you get the engine for free.
3500 lb is about all I'd want for cross country higher speed towing in today's normal traffic with a 60's wheelbase, regardless of "improvements." I don't really agree that it's crazy or you have to get another vehicle. I've had a bunch more than that on the hook and never felt it was unsafe.
We've taken a ~2k lb mini truck bed camper trailer I made on 3k miles round trips the last 2 years in my 62 (V8) and I honestly don't notice it back there.
I've towed with mine with the 3FE/A440 stock, on 33's with 4.88's, and now with a 5.3/NV4500/33's/4.88's (and now back to 4.11's). And yes, I did it all myself, swap was about $7k in parts, and the engine and trans was only $225 of that... it's not cheap.
My 100 is better on the road with this heavy old 19' Larson than the (now) more powerful FJ62. Yes it got dragged around with the 3FE too... but only locally.
A 60 here is rated to tow either 1500kg, 2500kg or 2900kg depending on who you ask.
Admittedly I've got more power than stock, but I'd tow 2k kg with it quite happily.
Properly working trailer brakes are a non-negotiable, and brake upgrade on the truck would be nice, I've found a good upgrade with an 80 series booster, but if I was starting again I'd try and get 80 series axles under it, or at least the FROR (from memory) kit on the front and an 80 series rear.
Engine-wise, something with boost is nice for the hills, esp. At high altitude.
Having said that, I tow heavy things with an F250 6.7 tremor and there's no going back. Especially over there where something similar is easy to get, you'd probably be better spending the money on a dedicated tow rig.
I haven’t towed with a 60 series wheelbase, but if the conversation is about powertrain I think it depends on your expectations - I’ve had two H150F-swapped 3FE powered FJ80s and I’ve towed all sorts of stuff with them. Most recently I towed a ‘97 Camry on a 2800lb float trailer (approx 6k lbs combined) on a hilly two lane highway. Was it fun? Not really. Did it do it? Yeah. I had to use the gears but I never dipped below 80kph. Locally it towed fine, and I’d do it again.
Also towed a 3k lb empty dump trailer, and then that same trailer with about a ton of boulders in it. Local roads, but towed fine. Anything 3k and under I don’t really bat an eye at, but again, my expectations are realistic. My 80 is also heavy, lots of drag and on 33” tires.
I do have rear airbags, and a good quality brake controller, which I would say are both musts. I will also say that with the automatic transmission it was an absolute dog when towing.
