the visors are perfect with labels intact.
Your Mom is perfect with the labels intact...
Seriously, the Runner looked amazing. It makes me kinda sad that I have to give mine up... Very well done and it was good meeting you.
I need to check my engine light code.. I am not spending $$$ on an O2 sensor.
also just to be clear. the post cat o2 is NEVER used for fuel trim.
it cannot be used in that manner because the cat changes the chemistry of the gases going through it.
Rear O2 sensors monitor the ecu corrrection of STFT, LTFT and catalytic efficiency. In the 80 OBDII Toyota also uses the rear O2 signal input to trim Baseline Fuel Values by about 2%. This is minimal, and common to account for reduced catalyst efficiency over the life of the cat.
with all due respect.
it is checking cat efficiency, which in a round about way is looking at the primary fuel adjustments.
for the sake of argument, if you go away from a toyota cat, or to a newly designed toyota cat. then its going to shoot the whole argument out of the water. i think what people dont really realize is the regular o2 sensors have a VERY limited line of sight. they are reading from about 14.6 to 14.8 ish.
so i think that any literature stating that the rear cat is doing anything other than giving the ecu a viewing window, is either wrong or has been misinterpreted.
I actually smogged back in december in my 96 OBD2 80 and passed even though with a scan tool it said "not ready" when they plugged into my port it even said not ready on his screen but the 80 passed the test anyways. maybe I just got lucky not sure.
